If so what paint did you I'm working on a table that I want to end up looking like a TD-121 (the single speed version of a 124) and no where can I find info on the proper paint to use.
I found this link. Hope it helps.
http://db.audioasylum.com/cgi/m.mpl?forum=vinyl&n=815520&highlight=TD124+paint
Gorgeous. :drool: There's a sticky (in DIY maybe?) about making your own dustcover. I intend to do that for my TD-125. Even though I have the standard plinth and could buy a new dustcover for it, I don't like the proportions of the originals (or the repros).
I haven't figured out hinges yet. I'm sure there are small spring loaded hinges available from cabinetry supply houses, but there'd be some experimentation required to get the load right I think. Could also just make one to lift on and off.
What shall I do for a dustcover? Do you guys have dustcovers for your TD 124?
How does your 124 rank against your old TD320 or Garrard 80 ?
I was quite surprised when I played a record on it because it had more soundstage than the Lab 80 or the TD320. The presence of the music seems to be more engulfing and solid bodied. I can't really explain it unless you're here to listen to it. Those explosive moments within the record groove get propelled into and out the speakers with a more efficient delivery. I notice a sharper, keener sense of rhythm. Drums leap out into the room with more suddenness. etc. This quality can be addictive. I don't know if it's because of the cartridge, or the belt/ idler drive combination in conjunction with the eddy brake that smooths it out. This is Awesome to say the least!
However if i get lazy with the interaction, I'll still use my Lab 80 for automation.![]()
Staying tuned.[/qu
Thats one sweet table! Wow. Words cant say enough!
Eric
