rufleruf
Preserving the sound
After having good luck (and lots of help!) getting an FM200B together that I bought thinking was a parts unit, I have decided to give this KM60 that came with the same lot of projects a go. This one is MUCH more apart and the chassis is decidedly ugly.
Where to start... I guess it would be nice to go crazy trying to clean up the chassis, but following my own advice I'll simply clean as best I can and neutralize the rust with some phosphoric acid 'rust mort/naval jelly' type stuff I have from working on old cars.
Functionally I need to sort out the missing aux AC plug and fuse holder, and hook back up the flying resistor and capacitor pictured. I'll of course replace the electrolytic and mylar capacitors. Can someone post a picture of the under-chassis area around the fuse of their KM60?
I should have most of the tubes I need in my vault. No idea how long it will take to buy all the missing knobs. I have some spares, but none of the two types this fellow needs.
If you read my post about the FM200B it ended with me stating I wanted to learn to do FM alignments - well, I'm fixing this so it can be my first subject.
And last - lucky me, I already have the assembly manuals for this.
