Super Noob
Now on to the 2nd on my non-working Yammies.
CR-620. Typically stay away from the lower WPC units = but it was essentially like a BOGO deal relating to their non-operational status - then add in discrete outputs and plenty of good things said about the 620, so I am in.
Guess it needs to be said again, the board drawings in the parts manual and part lists are subpar in regards to the other units that I have worked on; nonetheless, I proceed.
In less than 2 minutes the unit is up and running - simple re-flow of TR802, as noted by many previously TR802 runs hot and has been known to compromise its solder joint. After that... time for the rebuild.
A fair case could be made for the retaining the small transistors / diodes = but I changed them anyways.
Here is the cap summary and semi(s):
WORD:
https://drive.google.com/file/d/1MbJQ3PtP3vk5dMfZYBXn60ckIddioQID/view?usp=sharing
PDF:
https://drive.google.com/file/d/1-u_GFIZnGIbmTEpOhcWYtOW034LTxHis/view?usp=sharing
WORD:
PDF:
