joltman
I have got a JBL PB 12 subwoofer that I purchased in 2001. In about 2019, it decided to stop working. Long story for another thread, I have tested the NPN/PNP (Q2 and Q3) transistors in the power supply with an Peak Atlas DCA55 and they both test fine, however, given the scorch marks on the board, I'm hesitant to believe that. I've purchased a Heathkit IT-3121 to try t-shooting the transistors, but I'd like to find suitable replacements for these transistors:
MPSW06 (NPN)
MPSW56 (PNP)
Both of these are showing that they're low noise with about hfe of 100. Here is the schematic for this section of the circuit:
I'm having difficulty finding a suitable replacement for these transistors. Specifically, the Pd of 1W and Ic of 500mA all while trying to stay in the CBE/EBC lead order. I'm looking for advice. Would this transistor be a decent replacement for the NPN?
ZTX455 (NPN)
I'm having very little luck finding any PNP for this circuit in stock anywhere (ZTX555). Maybe the ZTX553??? If there's a better option to replace these, I'm all ears. Unfortunately, I am kind of stuck with the CBE/EBC lead order because the through holes on the PCB are in a straight line, so crossing the leads wouldn't be an easy task. I suppose I could do heat shrink around the legs. I have also seen the onsemi MPSA06 and MPSA56, however they don't dissipate enough wattage in comparison to the current transistors. I also feel like the rail voltage of 15V/-15V is really low for the current transistors, so I might be overthinking this?
I am also going to be replacing the Zener diodes as well, as it's likely they failed as well. The R6 and R9 resistors were badly scorched and they read very bad. Any help would be appreciated. Thanks!
MPSW06 (NPN)
MPSW56 (PNP)
ZTX455 (NPN)
