Pictured is the HT-50S from 1981 or so. I've never seen an HT-50K, but I imagine there might be one somewhere. Mine's a universal model with switchable voltage and an AC plug with adapter for 120VAC, just like one of my Hitachi HMA-8500 amps.
Nothing very special; typical '80s direct-drive: no suspended subchassis, just the usual plastic base with isolation handled solely by rubbery feet; lightweight ADC-type straight tonearm with semi-automatic operation (motorized lift, descent, and end-of-disc takeoff); vertical-movement bearings parallel to front edge of headshell; quartz lock with no speed adjustment; no speed readout, just an annunciator light that says LOCKED. What it has going for it is that low-mass tonearm, the aligned bearings and the [unique?] Unitorque cogless motor that does away with the heavy platters and fragile ring magnets of the Technics 'tables. In fact, the platter is so light that it could be a turnoff for a prospective buyer, but that light platter comes up to speed and locks in very quickly for a cheap table, and if you push on the rotating platter with your finger you can watch the LOCKED light go out and come right back on again as soon as you take your finger away. Not bad.
The best part, needless to say, is that almost no one remembers Hitachi's turntables, so they don't get bid up out of sight.
I was lucky and had an online auction seller who really listened to my warnings against leaving the platter on, etc. and did the most amazing job of packing it. And it was his first turntable! The late Joel Thorner would've been proud.
Photos from the web:
