flattedsixth
*in the headshell*
assuming all things are equal, does pressure increase on the cantilever when the cart is moved further out (end) of the headshell?
Hakaplan do you have any idea which one, Stevenson or Baerwald, that the Dennesen Soundtractor is?
oops, the direct link didn't work. sorry about that.
http://www.enjoythemusic.com/freestuff.htm
just scroll to where it says "click here for cartridge alignment tool".
You'll need to rotate it if the stylus won't land on the second point. The angle between the null points will only be correct for one mounting distance - I think Bkearns calculated it to be 222mm? The best way to use it is to ignore the arm specific angle (it's a red herring) and treat it as if it had the null points in a straight line (ie rotate between points) and it will work with any length arm - that is if you have room in the headshell, which goes for any universal protractor.I used the protractor everything has lined up nicely, the only thing is, the exact point from inner to outer is a bit longer from the bulls eye, it lines up on the sides just perfect, are you supposed to rotate the protractor a bit or should it land on the bulls eye's by just moving the tone arm from one null point to the other.
Well I did everything, it seems to line up perfectly with the lines on the sides at both null points, measured at 49mm. Sounds great, no distortion that I hear,
