Cesari0
Hi everyone, it's been a while since I have posted here. I have accumulated a few projects, and I have taken on 2 more turntable projects.
I have issues with two turntables, one I think it's an easy solution the other seems a bit more complex. And I'm really hoping to get some help from the members on this forum since they form an incredible pool of knowledge and solutions.
**Easy: I just acquired a Technics SP10-II. The issue is the stop/start button is not working. I have opened the unit and it appeared as if some liquid fell on the switch, I sprayed the mini micro switch with deoxit, but it didn't work. And the button does not stop the turntable. I would like to know the difficulty level of acquiring the micro switch, as I'm sure acquiring start/stop assembly is impossible. The turntable runs when the power supply unit is turned on.
Complex: I have had a Sony PS-2250 for a few months, it was playing fine, but I knew I had to check the oil lever, and there's only one way to do that, which is to disassemble the motor. I carefully took the motor apart, the bearing was bone dry, even the sponge around the bearing to absorb over fill was dry (the turntable kept proper speed though).
When I reassembled the motor after properly filling the well with a thin oil, the motor would start fast, it looked like it was about to come to proper speed, then it would shoot fast again. I had read that using thin oil on this turntable has some adverse consequences, so I took the motor apart again, dried the bearing, reassembled the motor, but the turntable keeps on shooting after slowing down to almost proper speed.
I would like to know if I ruined this unit, if I did it would be quite a shame since this turntable was quite superb with it's original arm. I'm about to order some caps online, I'm not sure if recapping it works will solve the issue since it wasn't there when I took the motor apart.
Any suggestions, solutions or opinions on these two turntables will be greatly appreciated.
