Haven't heard them, but . . .
https://www.stereophile.com/floorloudspeakers/704/index.html
Measurements are there, too. The reviewer was impressed with them, but remarks on their high power requirements - perfectly understandable with the rated 88dB efficiency.
GeeDeeEmm
Specifications:
Description (original Gold): Three-way loudspeaker. Drive units: 10" woofer, 6" midrange, 1" metal-dome tweeter. Crossover frequencies: 250Hz, 2.2kHz. Frequency response: 36Hz-20kHz ±1dB. Impedance: 4 ohms nominal. Power recommended: 10W minimum, rated for amplifiers of up to 250W clipping no more than 10% of the time. Sensitivity: 88dB/W/m.
Dimensions: 13.5" W by 44.5" H by 14.75" D. Weight: 95lbs net.
Price: $2000/pair (1991); $2100/pair (1997). Approximate number of dealers: 40.
Description Gold i: Three-way, reflex-loaded, floorstanding loudspeaker. Drive-units: 1" (25mm) ferrofluid-cooled, aluminum-dome tweeter; 6" (150mm) polypropylene-cone midrange unit; 10" (250mm) doped paper-cone woofer. Crossover frequencies: 250Hz, 2.2kHz. Crossover slopes: 24dB/octave Linkwitz-Riley (midrange/tweeter), 18dB/octave (midrange/woofer). Frequency response: 36Hz-20kHz, ±1dB; 31Hz-21kHz, ±3dB. Sensitivity: 88dB/W/m anechoic (2.83V). Nominal impedance: 4 ohms. Amplifier requirements: 15-300W.
Dimensions: 43.5" (1105mm) H by 12.25" (310mm) W by 16.5" (420mm) D. Weight: 95 lbs/pair (43.2kg/pair). Shipping weight: 111 lbs/pair (50.5kg/pair).
Finishes available: black oak, dark cherry, gloss black.
Serial numbers of units reviewed: None visible.
Price: $2399/pair in black or dark cherry. Approximate number of dealers: 230.
Manufacturer: PSB Speakers, The Lenbrook Group, 633 Granite Court, Pickering, Ontario L1W 3K1, Canada. Tel: (905) 831-6333. Fax: (905) 831-6936. Website:
www.psbspeakers.com.
Read more at
https://www.stereophile.com/content/psb-stratus-gold-loudspeaker-specifications#0w2Q4SQI5HqQZuOP.99
