Hi, I think you've been given really good advice about vintage turntables, and it's true that if you're patient, you will find a gem. Why don't you take some time to find out the things you need to check when you look at used tables, like bearings, functions, speed etc. There's a lot of advice on here about what to look for.Hey guys I want to purchase my first turntable, but tbh I have no idea what to look for in a turntable, which brands to look out for etc. I had one of those ION USB turntables, but I gave it to my girlfriend because I'm not really interested in ripping vinyl to my computer, and that thing was a cheap piece of **** anyway. I'm definitely in to vintage equipment, but I wouldn't balk at a nice modern turntable either. I would say my price range is right around $100. I want a nice turntable, that looks nice as well. Do you have any suggestions or advice for me?
I don't know if this makes a difference but the vinyl player will be hooked up to my Marantz 2325 via Phono port.
Thanks for reading
Regards, Alex
I would say to make your price range around $500; otherwise forget about it. Good luck....I would say my price range is right around $100. I want a nice turntable, that looks nice as well...
This fits your budget...
http://www.ebay.com/itm/DENON-DP-35...902573?hash=item236f0bd82d:g:HkUAAOSw7ehXTb~K
(no affiliation on my part)
Excuse me, but I see this referenced time and again. Will someone please quantify what exactly is a "beginner" turntable? I can see this term applied when you are learning to ride a motorcycle or such type of endeavour in which your lack of skill would necessitate a more forgiving piece of equipment in order to learn how to use it correctly.
"Beginner" or "entry level" is (IMO) most commonly used (for or toward) those just getting into vinyl or getting back into it after decades of being away from the format. Even if you were into it before, that doesn't mean that it is "it" for you now. If you never have experienced the format, you gotta start somewhere. Usually, it refers to a "minimal" or "entry level" budget to get your feet wet in the medium and still getting an acceptable level of performance/enjoyment. Vinyl may or may not be "it" for you. I appreciate vinyl, and don't mind getting up to change album sides, cleaning records, and storing/cataloguing crates upon crates of lps--a lot of people don't, won't and never will. Even if you "used to", now a days digital is so much more convenient and you can store my entire collection of 3600+ lps on a hard drive or thumb drive with instant random access.
"Most" people, do not jump with both feet (and a second mortgage) into a new hobby that they may or may not like/appreciate. God bless you if you have the resources to do so, and spend your money as you will, but "most" people are not going to dive in headfirst (credit cards a' blazin') to TRY something. You can get a "taste" of the vinyl experience/hassle (depending upon how you look at it) for a couple hundred bucks, or maybe even less. If you "likey, likey" then maybe it is something that you want to commit more time and resources to--if not, you are only out a couple hundred bucks, not tens of thousands.
As for "lack of skill" and "more forgiving piece of equipment"--I'd rather fumble finger around with a $50 cart than trash a $2K cart as my first "experimentation" with vinyl. You use the motorcycle analogy--and I ride--a 2015 CBR1000RR ABS, capable of nearly 200 mph and will snap your neck in ANY gear--should that be ANYONE's first bike???--I sincerely hope not!!!--with over 35 years on street bikes, I wouldn't start here. Buy a used "not so special" something and LEARN.
"Beginner" and "entry level" are NOT derogatory terms--but everything is what it is, and has it's limitations, and a potential path forward for upgrades, should you want to pursue it. I sincerely doubt that your first stereo purchase was from the "high-end" demo room with a complimentary espresso in your hand.
Excuse me, but I see this referenced time and again. Will someone please quantify what exactly is a "beginner" turntable? I can see this term applied when you are learning to ride a motorcycle or such type of endeavour in which your lack of skill would necessitate a more forgiving piece of equipment in order to learn how to use it correctly. A Turntable, at it's most basic, is a fairly simple mechanism. There are varying degrees of complexity and types of material used which would determine the price point of any particular table/cartridge combination. But I don't see how that would translate to beginner, mid-level, expert. etc. If I was new to this and have the $$$ to get a nice table, then why wouldn't I opt for that?
Exactly so. If you can afford an LP12, then buy one.Excuse me, but I see this referenced time and again. Will someone please quantify what exactly is a "beginner" turntable? I can see this term applied when you are learning to ride a motorcycle or such type of endeavour in which your lack of skill would necessitate a more forgiving piece of equipment in order to learn how to use it correctly. A Turntable, at it's most basic, is a fairly simple mechanism. There are varying degrees of complexity and types of material used which would determine the price point of any particular table/cartridge combination. But I don't see how that would translate to beginner, mid-level, expert. etc. If I was new to this and have the $$$ to get a nice table, then why wouldn't I opt for that?
