coylum
Well-Known Member
I have an output transformer suitable for distributed loading with EL84's in push pull mode.
The secondary appears to have two separate windings with the potential for 3 different output impedance combinations. Snag is I have no idea what the impedances are - I guess 4, 8 and 16 ohm but which one is which?
I know that I can measure turns ratio by injecting low AC voltage, getting a ratio and then calculating impedance. I understand how to do this for a single ended output where the primary is just two wires with no centre tap or screen grid taps but how do I do it with a push pull transformer? Do I inject the AC voltage across the two anode connections or between anode and centre tap?
