So , who out there has the desire to teach along with the patience to deal with a newbe? I have a couple of years with solid state but still very limited in audiophile knowledge although I never stop trying to learn ( pretty challenging when you’re born with a learning disability) . Now. . . Tube amps , can a few of you explain the push pull & single ended verbiage? Are they two types of circuitry? What are the pros & cons for each ? I’d like several opinions. Every one explains things a little different, but that could be of help to me . Thank you in advance .
Se’an from NJ 4/12/23
Basically, a single-ended amp uses a single power tube for the output. The advantages are (by general consensus) a "purer" sound, more realistic presentation of voices and instruments, and higher 2nd harmonic distortion, which many feel is "euphonic" and pleasing to the ears. All SE amps run in Class A, which many feel improves the sound quality of an amplifier. And the circuits can be extremely simple with a low parts count. The disadvantages are:
1) Low power. 20 wpc is about the most you can get from an SE amp, and that's with a high-voltage transmitting tube like the 845 or 211. Such tubes require more complicated circuits and power supplies. More typical is 3-10 wpc.
2) Generally high construction costs. You must have a very good-quality output transformer. It has to be constructed properly to handle the standing current produced by the output tube. You also need a heavily filtered power supply, which adds more heavy components like filtering chokes.
3) Relatively limited frequency response, depending on the quality of the output transformer.
Push-pull uses two tubes operating in opposite phase to produce 2x or more the power output of an SE circuit. The two phases are combined in the output transformer and sent to the speaker. The advantages are:
1) Much more power available, and generally better control of speakers.
2) Wider frequency response due to the construction of the output transformer, because the tube current is balanced between the two primary windings, allowing for better bandwidth.
3) Lower harmonic distortion, cancellation of 2nd order harmonics.
4) Generally lower construction costs. Simpler power supply, since most noise is cancelled at the output. Output transformer is (generally) cheaper and easier to manufacture.
1) More complicated circuitry, including a phase splitter stage to split phase to the two output tubes.
2) Crossover distortion, which can be inherent to a PP design but minimized to varying degrees.
3) Less of the "immediate" or "intimate" sound offered by SE amps.
Hope that helps!
