Q about ADS speakers
jay
For a long time I've watched ebay auctions of ADS speakers with the intention of bidding on them. Right now I'm using L-620 2-ways and like them so much that I want to 'step up' to some bigger 3-ways. I've seen both 710's and 810s that look good but can't really tell what the difference is between them. Does anyone here know what it is?
Are there any ADS' that are better? Which are considered 'the ones to get'? :confused:
There is an earlier thread concerning ADS that is full of photos and info, I brought it to the front for you to check out.
Hey, do one better than that. Get the original Bruans. Why settle for a knock off? I have the 710's made in West Germany. Sweet deal... :D
Thanks WW, message received. I've looked at ebay a long time and haven't come up with any genuine Brauns in a long time. Were they scarce or just disposable? ;)
One of my key words at E bay is Braun. I recently found some replacement woofer drivers for my 710's from some guy in Germany. I was thrilled about it as no one can replace the voice coils in these if you smoke em. Paid all of 35.00 bucks for them. Whew!
Yea, I never see much Braun stuff there either. Actually people keep these speakers because they are killer acustic suspension speakers. Well built cabinets and heafty crossovers. The large silk dome mid and tweet give a real good sound and the two 6" bass woofers were cutting edge design back in the day. ('72-'74) Up before that, the trend in home speakers was one large bass woofer driver. Also these speakers were not produced for long out of German. So there is likely not many out on the market like you might find in some other speakers out of the U.S.A. Like for instance the ADS line produced in thier image and with Braun drivers at first...
Here's a shot of one of the Braun 710's in my shop with the metal grill cover off. I power these with a similar vintage Heathkit integrated amp and Heathkit tuner. It's a fun combination!
I saw ONE 630 yesterday, the drivers in it look perfect, the cabinets, with the exception of a 'chunk' out of a rear upper corner, are quite nice. $10. Wish they had dropped off both speakers!
Shoot, think I'll go back now and check. Prolly get the one, eh?
ADS L-710 and L-810
Subject: Re: ads speakers
Date: 1999/05/24
Newsgroups: rec.audio.tubes
I have pair of ads L710's. 2 6" woofers, 2" soft dome, 1" soft dome.
Found at a garage sale along with a pair of L700's (similar, but didn't
have the 2" midrange dome, just the pair of 6" woofers and 1" soft
dome).
Had to refoam the woofers, everything else was fine. Tight, clean,
analytical sound, good depth of image, can play pretty loud when I want
them to. Bass is solid but a bit overdamped, probably down 3db at about
45 Hz. They sound great on stands that are about 18" high. I've been
listening to my 710s for about 8 months now, and am quite satisfied.
Especially considering my $$$ investment in them was next to $0.00! I
think I'll keep them until I win the lottery and upgrade to big Thiels
or Dunlavys.
The 810's, which I haven't heard in about 15 years, had a bit more bass
than the 710's due to the larger woofers in a cabinet that was only
slightly larger. You might want to check an old Orion guide, but I
recall the 710s selling for about $600/pr and the 810s maybe $750/pr in
1976. In the mid 70s ads, which sprung from German electronics
manufacturer Braun, had quite a line of nice speakers. Along with the
original Quad ESLs, the IMF (Irving Fried) studios, BBC LS3-5A, KEF, and
Spendor I recall the ads products performed very well in comparison to
lower priced speakers from Advent, EPI, Genesis, Infinity, and JBL. I
guess you could say the ads were what you would call "HI-END" audio in
the mid 70s.
Some ADS woofers had rubber surrounds (smooth material that looks like a
bicycle inner tube). These don't deteriorate at all with age. As
mentioned above, the ones I got had foam surrounds (looks like a grey
spongy plastic material) that had pretty much completely rotted away by
the time I got the speakers. I changed them myself, but if you want to
have someone else refoam the woofers, expect to spend $100-150 to get
all four done. I don't think the midranges or tweeters fail very often,
so if they make sound, they are probably fine. The crossovers in these
speakers are pretty bulletproof also.
One important thing to keep in mind is that these are definitely FOUR
ohm speakers (the dual woofers are each 8 ohms and are internally wired
in parallel). So make sure your power amp is up to handling the load.
In my system I have a DYNACO ST70 tube amp, which has 4 ohm taps for the
outputs.
Since these speakers are fairly efficient many tube amps will be
powerful enough to drive them. Also, since the speakers' natural sound
balance is just a bit on the bright (I prefer to say "analytical") side,
you may find that a tube amp tames the high end just enough to create a
really listenable balance.
Overall I would definitely recommend any of the 70s vintage ads
speakers!
"EB" Greg Danner / Audio-Video Service Center
This is an ad from a place near me that sells used audio.
Does anybody know where this model falls in the ADS lineup and when they were made?
Also, what about the price they are asking?
Thanks
ADS L-7E 2 way, 7" woofer and dome tweeter, sweet sounding, were on wall mounts and now have screw holes on the top and bottom, otherwise in excellent shape.
$195
"Some ADS woofers had rubber surrounds (smooth material that looks like a bicycle inner tube). These don't deteriorate at all with age. As mentioned above, the ones I got had foam surrounds (looks like a grey spongy plastic material) that had pretty much completely rotted away by the time I got the speakers"
ADS used to import the Braun driver for thier line of speakers. Hence the nice rubber surround. Then they went off and started making their own driver and that is where the foam came into play. If you find the older ADS line with the Braun drivers you are better off.
