Hi,
Heathkit W6(A-M) uses DC-coupled 12BH7 cathode follower to drive 6550 output tubes. Some variants have 12AU7 instead of 12BH7. In order to bias output tubes, driver's cathodes connected not to the GND, but to -180V negative bias supply via 10K resistors. At power on, when 12BH7 is still cold (warm-up time is about 11sec), voltage between plate and cathode is well over 600V DC - with plate current almost zero, 10K cathode and 12K plate resistors have no significant effect. Data sheet states max plate voltage for class A amp about 300V (450V for oscillator which is not our case).
Is this design flaw based on assumption that 12BH7 (12AU7) can tolerate startup over-voltage for quite long time, or I'm simply missing something?
Thanks.
Thanks.
