I am interested in the opinions of other QLS-1 owners in what ratio of power between the Watkins and the hi frequency drivers when bi amping your Infinity QLS-1's.
I am thinking unlike some of my other Infinity's when bi amping these Quantums might sound better with more power to the hi frequency drivers than just using equal power. On my RS-1's I have found that to be the opposite as I usually use an amp about twice the power for the base towers over that of the upper end towers. But I am thinking and help me out to see if I am wrong here, that the QLS-1's need more power for all them mids and EMIT's to get a good upper end balance over the bass from the Watkins. The amps I am currrently using I don't have the ablity to adjust the gain on the bass drivers amp, only the hi end amp, and I had it cranked all the way up and I felt that the mids and hi's were just not cutting it. I don't find that problem on the QLS-2's of mine and I think it has to do with having much less mids and hi drivers that its allowing for more mids and hi frequencys to be heard as I am losing less due to the amount of power that it takes to drive all those drivers in the QLS-1's.
Have all you owners that bi amp yours use equal power amps for both ranges or do you use your gains to equalize them, and what have you found to be a good balance as far as power for each range to work well.
Right now they are down, and I am using one of the pairs of QLS-2's that I own, and this pair doesn't have dual sets of binders for bi-amping and I find them to sound much better than the QLS-1's on the mids and hi end, just much more foward and not so subtle on the hi's.
Edit: I might find that the problem lies in the caps and pots, and I am currently working on them. But I still am interested in everyones opinion what they have found to be the best.
