QSilver
I got this today to add to my quadraphonic collection and to maybe try bi-amping some speakers. Everything looks reasonable inside although someone has sabotaged the front speaker outputs.
I powered it up and I've been trying to set the offset and idle current but I'm have problems....
I cant seem to be able to get it up to the idle current of 0.1V (100mV right?) I've not had a pioneer amp that whats so much idle current and I tried lifting it up to 80mV which took almost the entire trimmer pot on each amp.
The unit kept flicking in and out of protection but I've managed to set the dc offset which is under 10mV on each amplifier but again, I've almost had to turn the trimmer at least 3/4 of the way aroudn to get to set it on 3 of the 4 amp boards. The idle current doesn't seem to stay set after powering off.
I'm looking to recap this amp anyway due to the age its well overdue. Something else I noticed was that Q5 through to Q10 on each board are getting hot when its left idling. Is there some bad transistors somewhere or some big leakage from a cap or am I just not being brave enough to keep turning the trimmer?
It struck me as odd to think that the idle current wouldn't be getting near to its working voltage with the trimmer almost fully around...
Hopefully someone can point me in the right direction.
