crkeith65
Member
I am getting real close on this but I seem to be at a loss from this point on.
1. The Problem: Very low volume on FM and FM Stereo> In other words I have to turn the volume all the way up to even hear it. (AM AUX and Tape in work fine)
2. What I have noticed: Troubleshooting this problem I first found that I could inject an audio signal to the outputs Pins 14 and 15 of the F-1517 Tuner Circuit board and hear Audio which rules out dirty switches and pushbuttons, etc. Then I noticed that if I connected the wires that were connected to Pins 14 and 15 to JP6 and JP7 I could hear perfectly working FM Stereo which rules out any RF or IF problems. Next I noticed that if I reinstalled the wires to Pins 14 and 15 and then lifted R58 FM seemed to work fine. I could remove TR-11 with same results.
3. What I have done so far: I checked or replaced TR11, TR15, TR16, D05, C59, C47, and Checked the FM Muting switch which grounds Pin 9.
Someone good at analyzing schematics can probably pick this out in a matter of minutes. Not me I struggle at every level. I usually end up getting it but always takes too long. Please respond with any suggestions. Thanks.
Here is a link to my service manual:
http://akdatabase.org/AKview/albums/userpics/10007/Sansui QRX-5500A, QRX-7500A Service Manual.pdf
