QRX 7500A restoration thread
gdunlap
Hey all. I am pretty new to vintage audio restoration but I have a lot of similar experience from pinball restoration (diagnosing voltage issues, corroded connectors, board work, tearing apart and reassembling playfields, dealing with crufty 50 year old components.) I recently did some basic work on a Yamaha CR-440 and a Fisher CA-800 and was looking for a real project to sink my teeth into and saw someone advertising this QRX 7500A on CL. It has no case and, as you can see, has obviously been stored in a damp environment. However it powered up and clicked, the faceplate and knobs were decent, and I got tuner audio out of the front and back headphones when I tested it. so I decided to take it home for $100. Worst case scenario I figured I could part it out for that.
I'm currently weighing the idea of taking it down to the chassis and soaking it in Evaporust. I have done this with pinball parts a lot but the teardown here is obviously somewhat involved. The tuner face is cracked in front of the tuning meter so I'll be hunting for one of those. I also want to replace the hideous blue LEDs. Yes I know I am probably in over my head but that is part of the fun isn't it? :)
So having gotten it home, I put it on the DBT and got a good result so I deox'd the switches and pots and powered it up. So far so good. I have audio output from all four channels on both the A and B speakers through tuner and aux. I have not been able to test the preamp yet. All the controls are working as they should. It is pretty hissy so I'm guessing there's some caps and/or transistors to replace, and all the connectors need to be cleaned, but that's a pretty good result to start off from.
