QS-500 Configuration questions
I've got an RA-500 plugged in too, we match!
After a few weeks messing around with the two amps, still trying to find the sweet spot with the volume/balance. Let me know if your system gets louder when you disengage the 4 channel adapter.
The directions seem pretty daunting, but in a nutshell, the big black volume is now your overall volume and the level set is a gain control.
Oh yeah, I have all connections between the Receiver and the Quad set and have been fiddling with the levels until they're right where I prefer. I was wondering how to integrate the Reverb into the mix. Prior to buying the Quad, I had the Reverb connected to the 4 channel inputs on the receiver. That way, it worked automatically with whatever source material was playing. All I had to do was hit the 4 channel switch on the front of the receiver and it activated the reverb.
Now that I have the Quad Amp connected where the Reverb Amp used to be (4 channel receiver ports), I'm flummoxed as to where/how to connect the Reverb Amp. Do I just daisy chain it through (i.e., Quad Amp -> Reverb Amp -> Receiver) or is there a better way?
I've got the reverb plugged into Tape 1, which is what the RA-500 manual says to do (if I remember correctly). It'll operate exactly as the 4 channel input, because it (4 channel) is actually an additional tape input. The 5500 manual actually says you can use the 4 channel and noise reduction inputs if you need to add additional tape decks past the three provided!!
I usually keep it at its lowest setting, and leave it on all the time. I find it adds a nice warm brightness to the sound, interested to hear what you think.
I've got the reverb plugged into Tape 1, which is what the RA-500 manual says to do (if I remember correctly). It'll operate exactly as the 4 channel input, because it (4 channel) is actually an additional tape input labeled differently. The 5500 manual actually says you can use the 4 channel and noise reduction inputs if you need to add additional tape decks past the three provided!!
Awesome, thanks so much. I'll get on that and report back. This has been a huge help.
That's not reverb ... that's phase shifting. Part of the package in a Sui converter.
And yes, I have one in the rack, listen to it regularly, never hear a hint of what most would call "reverb", and am mightily impressed by the additional presence the adapter adds.
PS - worth repeating - it's all about proper adjustment of the line level and balance control. Not all that difficult, pretty much a one shot thang, and well worth the effort when you get it right.
Oh, yah ... here's mine, so let it be known, I walk the walk ... welcome to my laboratory ... ;-}
My QS-500 is doing something I think is unusual...was wondering if you would be willing to try something and tell me if yours does it as well??
Wow, thanks a ton.
A small world indeed! I too have a Sansui 5500, and a recently acquired QS-500, that I want to pair up! Can you share details (and possible a pic?) of how you wired everything together? I'm running Sansui SP-2500's on the front, and will be using SP-2000's on the rear. Thank you so much for any info you could share!
I really like your lab! I looked closely and see mainly a mix of dbx $ Sui. I use a dbx BX-3 amp in one of my racks. And I have two Sui quads and a dbx xover unit. I am very interested in which dbx pieces you use, especially the smaller, narrow pieces and what pieces are directly above your Mac on the left side. I am always looking for new methods/pieces to use. Please Feel free to pm me if you will/want. Thanks
