David_NC
In the quest to find a way to connect my SVS subwoofer to my Luxman receiver, I decided to try an electronic crossover, if I could find one cheap. A guy had a DBX 223XL for sale. At $25, I figured that qualified as cheap. I went by his house on Saturday, and he had a bunch of his stuff which had apparently been sitting unused at his church for sale. The crossover looks like new, so I decided to give it a shot. I had no way of testing it, as all my XLR cables are back in NC, so we'll see how it goes with that.
He also had a couple amps for sale. The one that was in the best condition and that has really good reviews was a QSC USA-900. Other than some masking tape residue, this unit also looks new. I connected to my trusty $5 Goodwill test speakers and a cobbled-together mono adapter - a 1/8" headphone jack to 1/4" plug (with Scotch tape over the R (ring) connector). I got sound and hum, of course, which was to be expected. I made my purchases, and off I went.
Antsy to try out the amp, I used an old stereo RCA cable with the plugs on one end missing. This amp has a screw terminal block, along with the combo TRS / XLR inputs, so this worked. I ended up with more hum than audio until I remembered balanced vs unbalanced + ground thing. After jumpering the ground to the negative terminals, the hum was gone. In fact, this amp is quiet... as quiet as the one in my Luxman receiver.
I listened to a couple albums and an SACD with my R-115 as a preamp (speakers are ADS L780/s). I can't say that there was no sound difference between the receiver's amp and the QSC, but it was really hard to tell which sounded better. The QSC definitely played louder and sounded a bit better at really high levels. I'd not normally listen to anything this loud, but it was quite impressive! I was concerned about cooling fan noise, but it's not an issue with this amp. The fan is only audible with very little ambient noise with my ear a foot or so from the amp. It's a larger 3U chassis with the large, slow-moving fan in the back blowing inwards. The exiting air was fairly warm, but definitely not hot.
The power rating of this amp is impressive, as is typical of DJ / pro amps: 240wpc, 20-20kHz @ .1%THD into 8Ω, 450WPC into 4Ω, and 900WPC into 8Ω bridged at 1%THD. I've read the back and forths about the quality (or lack of) of this type of amp, but I'm really impressed with this one. It seems to run cool. It has a lot of power. The transformer is very heavy. It sounds good. Oh, and QSC is a local company, and this amp is made in the US. What's not to like for $100?
These are definitely not good pics, but here they are (the interior shot is before I blew the dust out)!
