Raccoon1400
Idle current is a bit off in one channel. Supposed to be 10mA, measuring 14, and it is 14mA for the 1/3 of the pot, then it goes up.
i generally use croc clips and some wire to get a signal into amps if i haven't got the correct plugs .as long as your grounds are good it shouldn't hum much if at all .
i always check dc offset before connecting speakers unless its cap or transformer coupled output .
the bias might settle down when it stabilises .
when was it last in use ?
i would let it run for a while whilst monitoring the current ..and making sure nothing is getting hot .
blown fuse then or bad power switch .. voltage selector maybe .
power to the transformer primary ?
nice job .i may well have a 4 pin din plug here .. seem to remember some stereo mic.s having them ..
normally 5 pin for audio in / out .
a variac would be helpful here. if nothing else to save on fuses. using a VOM or DVM on X1 ohm scale im bettin' one of the AC line Rectifier diodes is dead shorted. it would help if i could see them. is this full wave or full wave bridge set up???
if you can disconnect the rails from the diodes. insert another fuse and pray.
if the fuse blows....diode
if it dosen't blow one of rails is shorted. measure again X1 scale from each rail to chassis ground. good luck
Yep, hooked to wall, playing now.So, are you plugged directly into the wall now? Why was it blowing fuses?
Thought it was a broken wire to the PT?
which version of the 303 is it, early or later, are the overcurrect diodes ok ? how do you know the board is taking 10ma
