My methods are crude but my next thought would be TO92 small signal transistors. I would make a list of what transistors are actually on the board then Google search those numbers in conjunction with "bad transistor" or "known bad transistor". Something might come up.
I was enlightened anout this when trouble shooting an Akai reel to reel. There were several reports of 2SC458 transistors in Akai products cited for being failure prone.
In addition to that reel to reel, I found that same transistor present in other brands/pieces of nonworking gear. Replacing them with modern substitutes fixed their problems.
It seems there are a number of transistors with a history of failure but maybe none as prevalent as 2SC458's. Apparently they were commonly used by a lot of manufacturers and in a variety of products.
Noise might also be created by IC's if your receiver has any. I have come to the conclusion in my own inexperienced way, that when there is noise, suspect the semi-conductors.
With no skills or equipment to do much diagnosing, sad to say I rely on arbitrary component replacement to solve problems. This past weekend, after replacing all small electrolytics and nearly all transistors, in a 45 plus year old receiver. it works splendidly now but sounded like crap when I started.
