Quadraphonic 4-channel vinyl
Back around 1975 or so I was working part time in an electronics store in Rochester NY. We had some decent hi-end for that time and I remember Quadraphonic 4-channel cartridges and tables, amps and vinyl source material on the sales floor. Did not seem that reliable and often one or more channels would not register.
Anyone else remember this audio "Edsel"?
Never tried it, some things I recall about using it.
I seem to recall that you needed low capacitance phono cables, a special cartridge and stylus, and a special phono preamp\decoder. :scratch2:
If you where unlucky to have played a CD-4 record with a damaged, low quality or mis-adjusted cartridge, you would "wipe out" the high frequency "carrier wave" that held the rear channel information. :no:
Another system used a matrix type system that did not have the above problems, I ran a simple "ambiance recovery" that worked quite well (my rear channel speakers need repairs). :sigh:
Mark T. :music:
I remember that wiring a back speaker or speakers without grounds to supposedly capture and reproduce ambient sounds. Results varied greatly.
Yes, I sure do remember quadraphonic sound. The original formats failed to catch on. More recent attempts at surround sound include dts CD, Dolby Digital, SACD, DVD-A and now Blu-Ray. :scratch2:
Also, CD-4 had the bad misfortune of just beginning to catch on in the era of 1973 oil shortage thin, often less than ideally pressed vinyl to boot. Which had more regrind in it's composition, and soft, delicate surfaces too often. Mastering a CD-4 disc required 1/2 speed equipped facilities, and plating and pressings had to be high quality for any performance out of said medium even on the best equipment available. And with the sheer amount of record releases then, plating quality was stretched thin. The Japanese made far superior CD-4 record pressings to any USA plant, theirs actually lasted more playings. and were on harder, quieter vinyl, which would stand up to the needs of CD-4 US plants were dealing with the oil crisis, increased demand for records, dealing with keeping price increases at bay. And much more.
I dabbled with 4 Channel for a while in the 70's. I remember listening to "Flight of the Bumble Bee" whizzing around my head while sitting in the middle of the 4 speakers. I had a Realistic Quad system for a short time, and borrowed my buddies 4 channel R2R player. I don't think I ever listened to 4 channel Vinyl. Perhaps. It's too long ago.
The details are fading in my memory.
I sold the 4 channel stuff in short order and stayed with Stereo. But I always used "Quatravox" on my STA-76, and do to this day when listening to that rig. It's simulated 4 channel that basically throws the rear 2 speakers out of phase from the front speaks and give you a synthesized 4 channel "effect" that really is more like an Echo Hall effect. I still like it. I always said I wished I had a medium power Rig with Quatravox instead of my meager 12 Watt STA-76. Perhaps some day.
I've got my dad's old 4-channel gear: turntable, decoder, and two Quad RTR decks. Holding off on listening to his 4-channel collection until I can attempt to do it "proper".
While I anticipate the experience of hearing what was for a time the New Cool Thing, I don't have such high hopes after reading Wendy Carlos' write-up on Quad's poor execution.
Her main criticism is the speaker positioning requirement - four corners with 90-degrees of arc between each - leaves big gaping holes in between them, in which sound and imaging suffers greatly.
Eventually when I get it running, I'll report my findings in our forums somewhere.
I have an old original stamping of B.B. King's "LA Midnight" in 4-channel that I purchased unopened in the mid 90's. The album has low noise levels and sounds terrific on my system today. I have to check and see where it was stamped. Vinyl quality does not seem to be an issue.
L.A. Midnight is superb. It was encoded in Sansui QS matrix format. Which was easier to handle than CD-4 was. Sansui's QS was the only really practical record system for 4 channel for everyone. It was fully backwards compatible, was the only system acceptable for broadcasting purposes, wasn't finicky, was usable for all. Other than Quad tapes. CD-4 wasn't suitable for mass market use here. And demanded too much. On mastering, on plating, on pressing, on playback equipment in homes, on setup and alignment, not practical for mom and pop.
Thanks for the info. Technical questions: How was a four channel signal encoded on the two sides of the record groove? When tracked in two channels, are the rear signals integrated into the left-right or not picked up? The album does really sound well with good separation, range, depth and soundstage. It also appears to NEVER have been re-issued as a CD or any other format. I have a friend who told me it's a rare album, especially considering its age and condition. Interesting to note that when I peeled off the plastic in the mid 90's, the paper inner sleeve had already yellowed from age even though it was never opened.
Sound was "encoded" in a 30KHz ultrasonic carrier signal using a form of modulation. Wikipedia has an article on how the process actually worked.
I recall cutting the power to my turntable motor and hearing the whistle of the carrier signal as the record slowed down.
Analog Qudraphonic died for many reasons. The main ones that come to mind are Hype (Manufacturers Marketing folks), Jive (Bad, non factual, ignorant sales force), Greed (Five different formats [get real!]), Complexity, & Consumer indifference (mainly cost). Then came along the CD craze that distracted the consumers.
Of course the record companies then all decided to adopt different versions of Quad formats which was a real hassle. The so called backwards compatibility was a joke because each format (SQ,QS, CD-4) needed the respective decoder.
Some folks got totally carried away with what is needed to play CD-4 encoded vinyl and that also confused potential consumers.
Just to clarify the formats there are a total of 5 (five) those being 1)QS, 2) QS Synthesized, 3) SQ, 4) CD-4, and 5) Four Track/ Four Channel Tape.
Quad records were and still expensive (When you can find them).
In light of the above some may think I am not a Quadraphonic fan. Quite the contrary, I have a QRX9001 (Completely Restored by a professional), driving four Pioneer CS-903 speakers (plus two passive subs), Turntable is Pioneer linear arm PL-L800 with a Grado Gold cartridge (Frequency Response 50,000 kHz). I tape off my quad records to a restored Teac A-3440 four track tape deck.
This is a hobby! I could not afford Quad when it came out and it "ain't what I need, it is what I want". My wife still doesn't understand.
For matrix type records, (QS, SQ and Stereo-4), the four original channels were put through a phase shift network and reduced to two channels. On playback a reverse matrix phase shifter then decoded the two channels into four. A regular stereo cartridge/turntable can be used to play back matrix format records.
For CD-4 records, a frequency modulated 30kHz. carrier signal was used to encode the rear channel information, that was demodulated on playback similar to the way FM stereo is demodulated/decoded. CD-4 records require a special cartridge to play back the high frequency modulated signals.
Yes.
I used to buy quad vinyl and play on my 2 channel system and it sounded better to me than regular vinyl.
That jogs loose a long forgotten memory. I seem to recall one or two of my friends buying Quad Vinyl saying it was simply amazing on their Stereo. I had forgotten about that long ago. I think at the time I brushed it off as a "Yea, right" sort of a thing, but your post has be thinking it may have been true, at least in part.
Yes.
The Shibata stylus shape was invented specifically for the correct playback of CD-4 LP's.
