Orlando S.
I know this is kind of a dumb question, but what do you guys use to make the little whole in the middle of a diy cork mat? To cut the mat out of the square piece of cork you just use normal scissors, right?
Do you use one piece of thick cork, ou two thinner ones glued together? I've seen both types. I've seen various places that recomend ironing the cork before cutting it, will this make the cork thinner?
I've found two sizes so far, 0.4mm and 0.6mm. If the ironing process makes the cork thinner i should buy 0.6mm!
Third question: how could i make a diy record clamp? What kind of wood do you people recomend?
