Andrew Heck
Howdy y’all, I’ve had new and very exciting changes/improvements to my system in the past few weeks and I’m not sure I’m utilizing these very powerful and awesome tools correctly. I’m hoping for an understandable explanation of gain as it applies to me and my system. As of right now, I’m trying to decide between a LOMC cart (.3mV) through a Parasound ZPhono set to MM following a pre-pre amp with a gain of 30dB (for MC cart levels) into or not into a passive pre with an attenuator (that’s my first choice) into a Schitt Vali 2 as a tube pre stage not sure of the gain at this stage, into my power amp, Parasound HCA 800ii At 100 WPC, which is going to change as soon as UPS gets here into an Acurus A150 At 150 WPC then into my Legend Audio LEG7000s rated for 150 @ 8 ohms....
As an option, I can also utilize a NAD 1300 pre, except the MC portion of the phono stage is not fully functional, so I still have to use the pre-pre in front of the MM amp, but I’m not sure how the preamp gain compares to the Schitt.
Am I ending up with too much at my power amp? How does one compute this so I can be better informed as I build and upgrade, should I use the passive in between phono stage an preamp? Is that a good way of tempering my 70+ dB phono gain? I feel like the sound is cluttered and constrained during complex passages. What does it all mean?
