imkristopher
Hello,
I have a pair of Alesis M1 Active Mk2s, and the tweeter on one of them has finally broken. The replacement process itself is easy enough, I was troubleshooting to see if it was a fuse or the tweeter itself by switching between the two monitors, and came to find that soldering isn't even required. I then took to the internet with a part number (7-02-0028) and only eBay links popped up. I'm a complete amateur and am wondering if I have to go with this replica from Hong Kong or if I don't even have to comply with the part number and can stick any third party tweeter in.
Specs of the tweeter:
4 ohm
1"
94mm Diameter Cut-Off Hole
75mm Diameter
30 watt RMS Impedance
91 dB Sensitivity
Any and all tips are appreciated
4 ohm
1"
75mm Diameter
91 dB Sensitivity
