TommyW
I have an Akai X-1810 that will run about 15 minutes and stop working. Motor appears to get hot. Saw a post where this is caused by the run capacitors. Looking at the unit there are three separate dual value AC capacitors. Two 3uf/1uf 260vac on each side and one smaller 2uf/1uf 260vac. I am assuming the single capacitor is the start capacitor and the other two are run capacitors. I read the dual values were for switching between 50Hz/60Hz, and I only needed to replace them with single value capacitors. Couple of questions.
1.) Looking at the attached schematic, am I making the correct assumption about the roles of these capacitors(run/start). Capacitors are highlighted in yellow.
2.) Have seen several suggestions about replacing them with ceiling fan capacitors. My concern with these are are they are cheap and will require replacement frequently.
3.) Can I just replace them with the single value capacitors for 60Hz?
Any advice or guidance would be appreciated. Thanks
