DSChamber
Well-Known Member
Hey guys/gals,
I own an Akai AT-2650 and I have a question about tuning in FM Stations.
The local radio station I usually listen to is 97.5 ...
Situation
During the day time I can tune this station in very well. My signal strength nearly "pegs out" and sits usually between 4.5 and 5 (with 5 being the top of the scale). I get FM Stereo lock and the FM stereo light lights up. Sound quality is fairly good, some faint static in the background but fairly clear. The FM selector is set to FM stereo auto
Now, fast forward to the night time, after the sun goes down I get the following behavior. Without moving the tuning dial from where I had it set in the daytime I lose FM Stereo lock and the FM Stereo light flicks in and out, there is a lot more static. The signal strength indicator meter, weirdly enough, stays nearly pegged out between 4-5. If I turn the FM selector knob to Mono I can listen to the station without any static.
Some observations I have noticed with my tuner.
1. When tuning in a station, lets use 97.5 for example, I notice that if I roll down to 97.0 and then start rolling up towards 97.5 I will have to go past 97.5 and the station will actually start coming in as I pass 98.0 and "lock" at say 98.1... then I can roll back to almost 97.5 without losing the station.
2. My FM tuning meter doesn't move at all (the one with the two bars on either side and you have to get the needle in the middle). On my Pioneer SX3600 my FM tuning meter moves so I know that it should.
3. The above behavior doesn't matter if I have the Noise Cancel ON or OFF, it also doesn't matter if I have the FM Mute ON or OFF.
Any suggestions on what to look for? I would love to get this tuner working 100% because I can listen to the tuner with it in MONO fine but you definitely lose sound quality when not in Stereo Mode. Plus it is a really nice looking silver faced tuner.
TIA!
Situation
TIA!
