the architect
AK Member
I'm in the process of building a record cleaning machine and I want to use a detachable 5-15p to c13 cord. After looking at potential c14 sockets I found this: http://www.digikey.com/scripts/DkSe...ang=en&keywords=708-1329-ND&x=15&y=17&cur=USD
Every c14 module with fuse holder I find is rated 10a 250v. I was wondering if I can use this in my application or should I use a standard 15a 125v receptacle? Those won't have a fuse and I like the idea of the fuse in case anything goes wrong. The AC circuit will have a gear motor, axial fan and vacuum which will add up to about 5a total. Will that module work?
