kahlfin1k
Well-Known Member
Well, I didn't like the sound when running wires directly from LF drivers to the amps (bypassing stock passive network). I set the slope at 6db on the Ashly but now also noticed the overall sound was just not as good as before, the bass from the LF drivers is not as tight. Seems the LFs are lacking with this setup.
I am not sure what adjustments are necessary to improve this. I will play with the Ashly settings more when I get a chance but does not seem to be much I could play with on Ashly.
Attached (not sure how to do this) is the speakers spec so not sure how to check "slope of the passive" per your suggestion. Can you provide guidance here from the schematic attached?
Thanks.
Don't see anything attached. If you PM me I'll give you my email and you can attach it. Most likely the reason it doesn't sound good is you have the wrong slope on the active as I suspected earlier you've significantly changed the tuning of the speaker. The 3 critical parts of a speaker design are the driver, cabinet and crossover. Change one and the whole house falls down. You can be sure that the fine engineers at JBL chose those three components very carefully.
