Hi all I have just switched from a reciever to seperates and am a little un sure on the connections. My system is a PC2002M amp, C80 pre amp, Sony SACD player and an audio source 8 equalizer. I was previously using a Sansui G-801 as a pre amp with a Carver TFM 25 amp hooked up through the Sansuis pre outs, I wanted to run my equalizer as well but couldnt because the pre outs were already being used by the amp. My question is will I plug the equalizer into the C80 or the PC2002M? And which connection should i hook it to? Thanks
