desertdog
Hello. I have had the B-2101 for about ten years....bought it from a friend at work. Excellent shape physically and sound-wise. Currently I have it hooked up in my system running two 4ohm 15" dual voice coil woofers. (I run my AU-11000 as my main amp with a Thorens TD-165 turntable. The B-2101 is in the tape loop and runs the subs, the AU-11000 runs the main speakers, which are also home-made).
I used to work at JBL in the days of yore, so I got the speaker-making bug and all but two pair I own are home-made designs.
Soooo, my B-2101 had no pre-amp, so I bought a Audio Source "Pre One" for that purpose and an Audio Source EQ also. That is the set-up for my vinyl.
Here's my question (s): The B2101 does its job well, but I know nothing about it. It certainly appears to be from a different era (newer) than the AU-11000. Is it a keeper? Should I reverse the amps and the roles they play in this system? What are your thoughts?
I have other Sansui gear, but I am just beginning to appreaciate it all.
Thanks for your thoughts!
Desert Dog
Desert Dog
