I thought I had the compliance-to-arm matching concept down, but maybe I don't... from Ortofon's brochure:
Well, with the weight plate, if you have a medium 12g eff. arm mass, the estimated resonance should ~8Hz with a 25 µm/mN OM, or ~7Hz with a 35 µm/mN OM. A little low, right? Taking off the weight moves that up almost 1Hz, so why do we want the weight here?
Say the arm mass was a feathery 4g or so, now they look pretty good with that weight, but if you take it off, the resonance moves up too high. Why does the Ortofon brochure seem to have it backward?
With the weight plate, the mass of a Super OM cartridge will be 5 grams - a perfect match for most "S" and "J" shape tonearms with detachable headshells. Without the weight plate, the mass is a mere 2.5 grams - suitable for low mass tonearms with detachable or fixed headshells.
