questions about my Harmon kardon 4 ch receiver
blooeyz
:banana:
  1. hi fellow AK'ers...
    I have a great working Harmon Kardon 4 channel stereo receiver model HK 100+. i also have a Marantz Model 4270 4 ch receiver..
    my question... is the HK equal to or similar to the Marantz in quality and power? i know the Marantz 4270 pumps out conservatively 70 watts rms per channel..and puts out 25 rms a ch in 4 ch.
    does the HK 100+ strap the same way? heck, i dont even know the power output of the HK 100+. anyone have an idea...what is the 2 and 4 ch power output for my HK 100+. Is it equal to the 4270 Marantz?
    thanks guys..
    blooeyz
:banana:
  1. my question... is the HK equal to or similar to the Marantz in quality and power? i know the Marantz 4270 pumps out conservatively 70 watts rms per channel..and puts out 25 rms a ch in 4 ch.
  1. The Harman Kardon 100+ has four separate power amplifiers that can be ganged for 2-channel stereo. There should be a switch on the back to convert it to two-channel mode. Make sure the unit is powered off before you change this switch. The 100+ is rated at 24 W/ch continuous into 8 ohms with all four channels driven or 57.5 W/ch for 2-channel stereo. It features built-in a SQ matrix decoder, main/remote speaker switches and twin power supplies. Original list price in 1974 was $599.95.
    The Marantz 4270 was rated at 25 W/ch @ 0.3% THD and IM. Original list price in 1974 was $699.95.
I would suspect that aging components are more likely to determine the sound and hence which one is actually better than reputation is. Marantz when it was owned by Saul Marantz is a different thing than Marantz under the several companies that have owned it subsequently. I believe under Superscope, equipment was designed in the US and built in Japan, and is well built and sounds good. HK has had some ups and downs reputationwise, but they have always been designed with an eye to actually sounding good, and tend to have things like seperate power supplies for seperate channels, which is demonstrably a good thing, unlike incrementally lower distortion specs and lots of useless knobs.
So both recievers have the potential to be good choices. But quad recievers have a lot of stuff in them that costs money and produces heat, even if you are not using the quad facilities, which means that they probably aren't built to the standards of the equivalent powered straight stereo reciever, and all those extra components create more potential failure points. But who knows -- its impossible to predict.
So I think that only listening will tell you which one is better.
