Hey Everyone. Long-time lurker at Audiokarma. Maybe I can puzzle some of you.
So after years with some interesting combos, I got a that early 80s Yamaha amp with no controls, and it came with two different cartridges - one for the special speakers, and one for regular speakers. I can never remember the model. Anyway, I adored the "Natural Sound" and I'm all in on Yamaha ever since.
So I gave that amp away and moved, and I'm starting over. I got an AX-750 that's in pretty good shape and two Canton GLE-50 three-way speakers... and I was having a birthday party the day they arrived, so I had very little time to do anything right.
Anyway, the Northern European model of the AX-750 says 6 ohms right on the back, even though it also says 270 watts, which is rated at 4 ohms. The other models are all rated for 4 ohms. Likewise, the speakers say 4 ohms, even though all the similar Canton speakers of that era say "4-6 ohms," because the Germans went through a period where they expressed both the rated ohms and the "lowest ohms" you can get with a speaker.
Additionally, I'm sending 270 watts to two speakers that are rated for like 60 watts each, although in all the forums, they say these Canton's are power hungry speakers. And I believe it, because right now they can haul ass.
So I am assuming that these Canton GLE speakers are not dropping below 4 ohms and are possibly 6 ohms, and that the amp can pull 4 ohms without blowing up. Because hell, it's a flagship amp and it should be able to pull 4 ohms.
The input selector switch is wonky and caused the right channel out when the amp arrived in the mail, an hour before the party... which led to a cascade of poor decisions. It causes all kinds of sound issues... from the L or R going out completely to delivering just parts of the sound. So at this party, I setup the speakers in series because I was moderately worried about the ohms and because the R was out. However, it was actually in parallel because I was drinking. So I ran the amp/speakers below 4 ohms all night... but not particularly loud. This means I was sending I don't know how many watts into these little speakers, as well as potentially killing the amp. Anyway, I discovered this the next day, and also discovered the wonky input selector.
So I don't have any spray to clean the switch yet. But I worked it back and forth pretty good, wired up the speakers as they were intended, and low and behold it sounded great. Really nice speakers... almost too accurate... but amazing on any record that had good production. The high damping of the amp is actually spectacular to behold, but woe to any poorly produced record. The speakers can really haul ass.
Now, I don't know if my ear was just off initially, or if this was going on the whole time, but it turns out that the mid-range speaker is completely out in both speakers. This may have happened in the last few days. I had them cranked up a couple times. But I have a hunch they must have died at some point between the party and today... though I can't be sure of that.
So - what in the hell do I have to do, and what tools do I need? Where do I start? I'm eager to take matters into my own hands here. I'm gonna do whatever it takes.
And I'll not be abandoning the thread.
which is certainly possible in your blitzed condition
. What seems surprising is that you didn't blow up the tweeters also which make me suspect that the mids may have been defective to start. Certainly I would take them out of the speaker and test them with an ohm meter or if you don't have that with a AA or 9 volt battery. Hook wires to the battery and the mid speaker terminals and see if you get any sound.
