Kreshna
...but I have to know.
The speaker stuffing inside my JBL 120Ti has become thin and dried up, and while it doesn't seem to affect tonality and details, sometimes I get the feeling that the sound is "boxy". The questions are:
(1) what is the stuffing materials used inside the 120Tis? I've googled but failed to find the material type.
(2) it's likely the 120Tis use fiberglass stuffing, since fiberglass seems to be the most common type. However, if I replace it with wool stuffing (like this), how much it will change the speaker's sound characteristics? And will it be better or worse?
(3) too bad the 120Tis' cutaway doesn't show its correct stuffing layout, but based on common sense (and after peeking into the speakers after taking off the woofers), it seems the stuffing layout is as follows:
- all sides (front, back, left, right, top, bottom) should be covered by stuffing.
- the stuffing covering the back side should be cut out (rectangular-shaped) to give way for the crossover.
- the stuffing covering the front should be cut out (circles) to give way for the back of the woofer.
- however, it seems the back of the tweeter and midrange are still covered by the front stuffing. There are only small cuts for cables, but the driver's backside is still covered by the stuffing materials.
Am I correct so far? Any further tips?
Many thanks.
Many thanks.
