AA6U
Normally I would never consider winding crossover inductors, but someone wants me to build them two JBL N2600 crossovers almost from scratch. Someone had gutted the original crossovers and left only the box, switches and pots. Fortunately, it's a relatively simple crossover with few components. The capacitors were not a problem. The inductors are.
Each crossover needs a 1.4 mH inductor tapped at .7 mH. I bought a 1.5mH iron core inductor (18 gage wire) from Parts Express (air inductors are too big for the set up and cost too much for the speaker owner). I then used a B&K 879B LCR meter as a guide to remove windings to bring it to 1.4 mH.
I then needed to create the center tap, so I had to unwind all of the wire and add a tap halfway along the wire. I then wound it back on the iron core but found the inductance had decreased from 1.4 mH to 1.18 mH. Note that I could not wind the wire back as neatly or tightly as the original winding so that probably explains the lower inductance.
In measuring the center tap after winding the inductor, I found one side measures 360 uH and the other measures 250 uH which only add up to 610 uH, about half of the 1.18 mH total measurement from end to end of the entire inductor. I found that the lower value section was the outer windings, which makes sense, but I am confused as to why the two do not add up to 1.18 mH, the total measured for the inductor. Note that I rechecked the measurements on a Sencore "Z Meter" and they were close to the B&K measurements.
Does anyone have any guidance for me in winding these coils with a correct center tap other than by trial and error and also explain why the sum of the two half measurements do not equal the whole?
