Capgun
Finjima, I'll have to look at my local Home Depot, and Lowe's, for the best price, since it will be an experiment. I've noticed, there are different thicknesses, when I ordered them. I have to make sure the length and width stay the same. I'm thinking of first, using a regular coat hanger, using some spray on silicone, then heating the wire up, with a heat gun that I have, or a hobby iron, that lays out and glues Monokote, onto wooden R/C Planes. If that doesn't work, I'm going to use my BernzOmatic hand torch on the wire. I'm going to join 2 of the thin foam cuts together, using either, the light 3M adhesive spray on glue, or the slightly heavier 3M 77. Using a light coat, on each piece.
Hjames, Thank you. I will do that, when I'm ready to attach to the frames. I was thinking of using Duct Seal, but I like you're idea better.
