bjlefebvre
Finished wiring up my DIY 2w/ch SET amp and turned it on via a 40w dim bulb tester. The bulb burns only slightly for the first ~10 seconds, which I know is a good sign. But as the amp warms up - as the tubes start to glow - the bulb starts burning more brightly. Is that normal, or a warning sign? For the love of Mike I don't want to see any "magic smoke."
Also, now that I'm thinking of it - is it ok to test voltages on the PCB board while the dim bulb tester is in the circuit? I'm assuming that readings would not come back correctly.
