audiodogster
So I am taking some equipment into the studio at my school to test. I have my Genelec 8050As, some Cerwin Vega CV118 subs, and a Samson SX1200 amp (class AB). As everything in that environment uses XLR connectors and the Samson outputs to normal binding posts, I need to bring along some speakers to test the amp with. The question would be can I safely have my Klipsch La Scalas hooked up to this amp and have the amp's volume dials turned way down to test the amp? The La Scalas can take 200 watts at 8 ohm but with a SPL of 104 dB at 1 watt at 1 meter, I'd probably be having hearing damage before I get to 50 watts. The amp is 300wpc at 8 ohm. The other option would be to take long my Martin Logan Theater center channel that is up to 500w RMS at 4 ohm, but it has crushed tweeters and I don't know if that could cause more damage to the speaker or the amp. I could also take my Monitor Audio Studio 6 which are 200 watts at 8 ohm. I just don't want to damage anything including my hearing.
