For various space reasons I occasionally find it necessary to place a turntable on the same surface or in the same bookshelf as the speakers and I have been thinking about good ways to better isolate the turntable from the speakers. Night before last, as I picked my way through the basement shop I saw a 1 3/4" slab of oak leftover from an abortive coffee table project. Whipping out my tape measure I realized that sawing it in half would give me the perfect-sized platform to hold a turntable. So, finally giving up on the coffee table, I sawed it in half.
The wood was very rough and uneven, so I ran it through my buddy Peter's drum sander about 50 times to make both sides perfectly flat and parallel.
After that, I routed the edges and sanded the surfaces multiple times, starting with 120 and ending with 320 grit.
Next, I used a 1 1/4" spade bit to drill holes near the corners just large enough to wedge part of a squash ball into.
I routed out the edges of the holes to improve the fit.
...and then finished the surface with a great poly-urethane finish called 'The Good Stuff' (no affiliation).
