Completed entering all of the parts for the boards on the QX-949 following the service manual and cross checking the boards in my unit. I've followed the advice of MTF in various threads and BOM lists for other Pioneers. Listed replacements using the following method.
1. cap < 1 µF: Wima film cap
2. cap > 1µF cea: Nichicon UPW cap
3. cap > 1 µF cssa/csza: Nichicon UKL cap
4. transistor replacements from "bad transistor list" on AK
Please post any alterations or places I have gone wrong. I'm hoping to start with the power amp board, then power supply, control amp, protection. Will do all bad transistors first (2SA720, 726, 2SC1451) and recap the boards where those are found (power amp, control amp, power supply). Currently out of KSC1845, so need to put in a mouser order before starting.
Boards are listed in order found in the service manual. If this listing generally looks ok, I will post the remaining boards. All replacement part numbers are Mouser part numbers with capacitance and voltage indicated.
Control Amp Board
Model Board Symbol Cap V Part No. Replacement Cap V
QX-949 AWG-023-0 C5 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C6 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C7 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C8 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C13 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C14 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C15 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C16 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C25 4.7 25 CSSA 4R7P 25 647-UKL1E4R7KDDANA 4.7 25
QX-949 AWG-023-0 C26 4.7 25 CSSA 4R7P 25 647-UKL1E4R7KDDANA 4.7 25
QX-949 AWG-023-0 C27 4.7 25 CSSA 4R7P 25 647-UKL1E4R7KDDANA 4.7 25
QX-949 AWG-023-0 C28 4.7 25 CSSA 4R7P 25 647-UKL1E4R7KDDANA 4.7 25
QX-949 AWG-023-0 C37 10 25 CEA 100P 25 647-UPW1E100MDD1TD 10 25
QX-949 AWG-023-0 C38 10 25 CEA 100P 25 647-UPW1E100MDD1TD 10 25
QX-949 AWG-023-0 C39 10 25 CEA 100P 25 647-UPW1E100MDD1TD 10 25
QX-949 AWG-023-0 C40 10 25 CEA 100P 25 647-UPW1E100MDD1TD 10 25
QX-949 AWG-023-0 C49 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C50 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C51 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C52 100 6 CEA 101P 6 647-UPW1A101MDD 100 10
QX-949 AWG-023-0 C53 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C54 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C55 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C56 47 50 CEA 470P 50 647-UPW1H470MED 47 50
QX-949 AWG-023-0 C57 2.2 25 CSSA 2R2P 25 647-UKL1H2R2MDDANA 2.2 50
QX-949 AWG-023-0 C58 2.2 25 CSSA 2R2P 25 647-UKL1H2R2MDDANA 2.2 50
QX-949 AWG-023-0 C59 2.2 25 CSSA 2R2P 25 647-UKL1H2R2MDDANA 2.2 50
QX-949 AWG-023-0 C60 2.2 25 CSSA 2R2P 25 647-UKL1H2R2MDDANA 2.2 50
Model Board Symbol Part No. Replacement
QX-949 AWG-023-0 Q1 2SK30A-Y, GR (FET) LEAVE
QX-949 AWG-023-0 Q2 2SK30A-Y, GR (FET) LEAVE
QX-949 AWG-023-0 Q3 2SK30A-Y, GR (FET) LEAVE
QX-949 AWG-023-0 Q4 2SK30A-Y, GR (FET) LEAVE
QX-949 AWG-023-0 Q5 2SA725-F, G 512-KSA992FBU
QX-949 AWG-023-0 Q6 2SA725-F, G 512-KSA992FBU
QX-949 AWG-023-0 Q72SA725-F, G 512-KSA992FBU
QX-949 AWG-023-0 Q8 2SA725-F, G 512-KSA992FBU
QX-949 AWG-023-0 Q9 2SC1312-F, G 512-KSC1845FTA
QX-949 AWG-023-0 Q10 2SC1312-F, G 512-KSC1845FTA
QX-949 AWG-023-0 Q11 2SC1312-F, G 512-KSC1845FTA
QX-949 AWG-023-0 Q12 2SC1312-F, G 512-KSC1845FTA
Power Amp Board Note: there are two power amp boards (A and B in service manual) so all parts quantities must be doubled.
QX-949 AWH-027-0 C1 0.22 35 CSZA R22M 35 505-MKS2C032201BKI00 0.22 63
QX-949 AWH-027-0 C2 0.22 35 CSZA R22M 35 505-MKS2C032201BKI00 0.22 63
QX-949 AWH-027-0 C3 33 16 CEA 300P 16 647-UPW1C330MDD6 33 16
QX-949 AWH-027-0 C4 33 16 CEA 300P 16 647-UPW1C330MDD6 33 16
QX-949 AWH-027-0 C5 0.47 35 CSZA R47M 35 505-MKS2D034701E00JI 0.47 100
QX-949 AWH-027-0 C6 0.47 35 CSZA R47M 35 505-MKS2D034701E00JI 0.47 100
QX-949 AWH-027-0 C11 330 10 CEA 331P 10 647-UPW1A331MPD 330 10
QX-949 AWH-027-0 C12 330 10 CEA 331P 10 647-UPW1A331MPD 330 10
QX-949 AWH-027-0 C13 3.3 50 CEA 3R3P 50 647-UPW1H3R3MDD 3.3 50
QX-949 AWH-027-0 C14 3.3 50 CEA 3R3P 50 647-UPW1H3R3MDD 3.3 50
QX-949 AWH-027-0 C17 100 50 CEA 101P 50 647-UPW1H101MPD 100 50
QX-949 AWH-027-0 C18 100 50 CEA 101P 50 647-UPW1H101MPD 100 50
QX-949 AWH-027-0 Q1 2SA726-G, F 512-KSA992FBU
QX-949 AWH-027-0 Q2 2SA726-G, F 512-KSA992FBU
QX-949 AWH-027-0 Q3 2SA726-G, F 512-KSA992FBU
QX-949 AWH-027-0 Q4 2SA726-G, F 512-KSA992FBU
QX-949 AWH-027-0 Q5 2SC869-C, D 512-KSC2383YTA
QX-949 AWH-027-0 Q6 2SC869-C, D 512-KSC2383YTA
QX-949 AWH-027-0 Q7 2SC1451-V, B 512-KSC3503DSTU
QX-949 AWH-027-0 Q8 2SC1451-V, B 512-KSC3503DSTU
QX-949 AWH-027-0 Q9 2SD357-C, D
QX-949 AWH-027-0 Q10 2SD358-C, D
QX-949 AWH-027-0 Q11 2SB527-C, D
QX-949 AWH-027-0 Q12 2SB528-C, D
QX-949 AWH-027-0 Q13 2SD370-R, O
QX-949 AWH-027-0 Q14 2SC1079-R, Y
QX-949 AWH-027-0 Q15 2SB530-R, O
QX-949 AWH-027-0 Q16 2SA679-R, T
Protection Board
QX-949 AWM-049-A C1 0.22 10 CSSA R22M 10 505-MKS2C032201BKI00 0.22 63
QX-949 AWM-049-A C2 0.22 10 CSSA R22M 10 505-MKS2C032201BKI00 0.22 63
QX-949 AWM-049-A C3 0.22 10 CSSA R22M 10 505-MKS2C032201BKI00 0.22 63
QX-949 AWM-049-A C4 0.22 10 CSSA R22M 10 505-MKS2C032201BKI00 0.22 63
QX-949 AWM-049-A C5 470 6.3 CEA 471P 6 647-UPW1A471MPD 470 10
QX-949 AWM-049-A C6 470 6.3 CEA 471P 6 647-UPW1A471MPD 470 10
QX-949 AWM-049-A C7 100 25 CEA 101P 10 647-UPW1E101MED 100 25
QX-949 AWM-049-A C8 4.7 25 CEA 4R7P 25 647-UPW1E4R7MDD 4.7 25
QX-949 AWM-049-A Q1 2SC869-C, D, B 512-KSC1845FTA
QX-949 AWM-049-A Q2 2SC869-C, D, B 512-KSC1845FTA
QX-949 AWM-049-A Q3 2SC869-C, D, B 512-KSC1845FTA
QX-949 AWM-049-A Q4 2SC869-C, D, B 512-KSC1845FTA
QX-949 AWM-049-A Q5 2SC945-R, Q 512-KSC1845FTA
QX-949 AWM-049-A Q6 2SC945-R, Q 512-KSC1845FTA
QX-949 AWM-049-A Q7 2SA733-R, Q 512-KSA992FBU
QX-949 AWM-049-A Q8 2SC945-R, Q 512-KSC2383YTA
QX-949 AWM-049-A Q9 2SC1384-Q, R 512-KSC2690AYS
Power Supply
QX-949 AWR-038-0 C6 470 16 CEA 471P 16 647-UPW1C471MPD 470 16
QX-949 AWR-038-0 C7 470 16 CEA 471P 16 647-UPW1C471MPD 470 16
QX-949 AWR-038-0 C10 220 50 CEA 221P 50 647-UPW1J221MPD 220 63
QX-949 AWR-038-0 C11 100 16 CEA 101P 16 647-UPW1C101MED 100 16
QX-949 AWR-038-0 C12 220 50 CEA 221P 50 647-UPW1J221MPD 220 63
QX-949 AWR-038-0 C13 220 50 CEA 221P 50 647-UPW1J221MPD 220 63
QX-949 AWR-038-0 C14 100 16 CEA 101P 16 647-UPW1C101MED 100 16
QX-949 AWR-038-0 C16 220 50 CEA 221P 50 647-UPW1J221MPD 220 63
QX-949 AWR-038-0 C18 100 16 CEA 101P 16 647-UPW1C101MED 100 16
QX-949 AWR-038-0 C19 330 35 CEA 331P 35 647-UPW1H331MPD 330 50
QX-949 AWR-038-0 C20 1000 63 CEB102P 63 647-TVX1J102MCD 1000 63
QX-949 AWR-038-0 Pn 14-15 10 50 647-UPW1H100MDD 10 50
QX-949 AWR-038-0 Q1 2SD313P-E or D
QX-949 AWR-038-0 Q2 2SC1318-Q or R
QX-949 AWR-038-0 Q3 2SC945-R or Q 512-KSC1845FTA
QX-949 AWR-038-0 Q4 2SD313P-E or D
QX-949 AWR-038-0 Q5 2SB507P-E or D 512-KSA940TU
QX-949 AWR-038-0 Q6 2SA720-Q or R 512-KSA1013YTA
Edit 3/7/18: made changes as per MTF post #2
Edit 3/8/18: text formatting
Edit 3/30/18: added replacement for 2SB507P on power supply board
Control Amp Board
Protection Board
Power Supply
