I don't doubt that ranballen's motor is a Synchron motor. What I am questioning is whether it is the same motor as the Synchron in the Weathers. Given that it appears to be lower wattage and doesn't have enough torque to run even the platter by itself, much less the arm (which is driven by a belt off the spindle), it seems to me that the Surplus Sales of Nebraska motor may not be a viable alternative. And trying one out isn't cheap.
I was curious, so I did a bit of research, and found a couple of threads about the ST4, and in one from 2018, I found a post I made about the motors in my two ST4s, in which I describe them as being like the motors in the AR, and mention the insecure mating of the clamshell top and bottom. While it is possible that, even in 2018, I was misremembering, but I think it is quite likely that Rabco could have changed motors during production. And I didn't identify the motors I had as Hursts - I don't know who made them, though if they said Synchron on them, I think I would have noticed. And my memory is that the case was not brass, but rather aluminum or steel or some similar colored metal.
I believe I am correct that on/off switch gives the platter a kick to get it going - that was mentioned in the threads I read.
I think the "kick" you're thinking of is the brake releasing. Mine always turns clockwise a bit, even with the power off, when it's switched to "on" and the brake lets go.
Progress with the motor hunt:
Hurst SB series 4005-001, 7W. Nice motor, but very noisy.
Hurst PB series 3204-029, 10W. Nice motor and quiet with the gearbox removed, but the shaft is quite short due to the gearbox.
In today's mail: Hurst PB series SP-3628, 600 RPM, 10W (I believe this is the same as the 3203-001, the specs are the same). The .82uF run cap will be in next week, but this motor should be just as quiet as the 3204-029. It has a shaft that's approximately 3/16" in diameter, which will not only require boring the pulley opening out quite a bit, but the boss in the bottom of the pulley that extends the center level with the bottom of the outside edge will be completely gone. In order to make sure the pulley sits at the right level when it's pressed onto the shaft, I've ordered a 3/16" shaft collar with a set screw to mount on the shaft as a stop. Next step, designing a motor bracket. Mounting it so the center of the shaft lines up with the location of the center of the existing motor shaft will put the edge of the motor very close to the cutout in the top plate, but I will also have to set the top of the motor a bit lower than the original Synchron motor to accommodate a raised area in the top plate that surrounds the shaft. In the end, this should be a significant upgrade to the ST-4.
I may do a bit of tinkering to see if there is any benefit to replacing the gear-drive Synchron motor that operates the cueing mechanism with a more powerful Hurst gear-drive motor, and if one would fit in the available space.
Dumb question: the Hurst synchronous motor is a four wire power input, vs. the Synchron's two wire setup. Two blue wires, one black, one red. The blue wires are connected together to one side of the power line, the red and black are connected together with a capacitor between them. Which wire (red or black) has the direct, no-capacitor connection to the power line determines whether the motor rotates clockwise or counterclockwise. The original design has a 0.1uF capacitor and 100 ohm resistor parallel with the on-off switch. I assume that's there for dampening purposes and not as a motor run cap? Confusingly, the gear-drive Synchron motor for the cue lift/drop also has a 0.1uF capacitor, this time with a 220 ohm resistor, but it's placed across the power connections to the motor and not parallel to any of the three switches connected to that motor. Per the service bulletins, that cap and resistor have something to due with proper operation of the motor when the cue switch or the electrical end-of-record sensor is activated, though I'm not really sure what. Two-wire Synchron motors tend to just work when power is applied to them. The electrical design of this thing is a wee bit confusing, considering how few parts it has.
