radial stereo beacon lamp in a housing
rooney53
Am having trouble locating a 14v/80ma/4.12mm radial stereo beacon lamp that is in a housing for a Rotel RX-402. Have everything else working but no one , even dgwojo69@msn has an answer for this. I'm sooo close to getting it back to original!!! Help, if you can.
Is the diameter the problem? 14V/80mA lamps with radial leads are readily available otherwise... the ones I stock & sell are closer to 5mm though (0.230 " diameter). Is the clearance that tight?
John
