Yes, that's a repaired diaphragm. I have to say, I love those Radians, one thing to try, reverse the polarity on the wiring to the Radian, based on your description of the sound compare it sounds out of phase to me, please update us!! :sigh:
@bowtie427ssResurrecting an old thread here... I'm trying these Radian diaphragms on a pair of 605's, and I'm a bit confused about the wiring. Should the L1 tap connect to the marked red (positive?) on the diaphragm? According to Altec literature, L2 is positive, but that would mean reversing the leads for the Radian....
Hi,
I usually take a AA or AAA battery and "momentarily" attach it to the the diaphragm input terminals, correct polarity is when the diaphragm gets sucked in or forward toward the horn (opposite of how a woofer reacts), observe which lead is attached to the positive on the battery. If polarity is reversed, the diaphragm will push away from the magnet and horn throat. I use a red marker on the input lugs once positive is confirmed, L1 and L2 terminology gets a little confusing, L1 on horns (compression drivers) it's usually negative and on woofers positive, it's all about which polarity will cause forward movement toward the front of the speaker, confused yet?
I'm not surprised the 475s were pleasing, one of the finest horns I heard were early Unitys at Tom Danley's house when he was using the 475. As I recall he got away from the 475 in production use because it wasn't robust enough for his professional use but he liked the sound and the tested response very much.
The Radians are true "Southern California" drivers with a developmental link back to Emilar and Altec. They are grandchildren of Jim Lansing and John Hilliard, the Poseiden and Zeus of the Great Southern California Horn Gods.
The 288/291...Man I wish Radian still made diaphragms for...
The 288/291...
