radioactive
tube gear fanatic
Chris, send me your address, and it can pay a visit.![]()
Temtpting:scratch2:
I have a single RC-500, RC-400 and three RC-2 Craftmen amplifiers. The RC-500 is clearly the winner. The RC-2 amplifiers are much earlier and have an additional gain stage making them unusually sensitive. I found that bypassing that first stage lowered the gain and significantly reduced the hum and noise. With that simple modification, the RC-2 sounded very good, depending on the speakers used. I used them with a pair of QUAD ('57) electrostatic loudspeakers and that combination was synergistic.
RC-500
Hello,
i owned (and own) and restored several RC 500 and 500a over the last 20 years. Soundwise the early 500 (without a) is the clear winner.
WE was the manufacturer of the RC500 output transformers.
You couldnt -according to the original RC service manual- get a new one without swapping your defect transformer.
gourmet
The first two generations of C500 was mostly worked by Sid Smith and licensed by Western Electric. The first generation C500 was introduced in 1951, it comes with a smooth corner Stancor output transformer. In 1952, smooth corner version replaced by the sharp corner version output. Radio Craftsman C500 is based on Williamson design which operated with 2 x KT66 output tube in triode but pure class A operation with 10 watt output. It has very natural sweet, clear and transparent tone. However, it has very clear, natural, realistic and transparent tone than many vintage and modern hi-fi amp.
The Radio Craftsman C500 was replaced by C500A in 1953 and the same years Sid Smith left Radio Craftsman. I believe the Radio C500A is the final work of Sid Smith. The different between Radio Craftsman C500A is it has much higher plate voltage in triode class AB and the output increase to 15 watts per channel. It also has much large size choke than C500, it also licensed by Western Electric as well. The rectifier tube also changed to 5U4G instead of 5V4G.
The final version is Radio Craftsman C550 and it replaced Radio Craftsman C500A in 1954. Honestly, the sound of Radio Craftsman C550 sounds slightly different than C500 and C550A, it has better body but not as transparent sweet and natural than C500 and C500A. The reason is simple, the C550 is operated in Ultra-linear instead of triode operation, the output also increase to 30 watt instead of 15 watts. The amplifier also used a B+ delayed turn-on via a slow warm-up, it required 60 seconds to preserve the cathodes on the KT-66s. FYI, Radio Craftsman C550 was not designed by Sid Smith, but actually designed by Bob Grodinski, this guy took over Sid smith work as Smith already left the company and joined Marantz in summer of 1954...!
Hello,
gourmet
Just curious why you like the 500 over the 500c?
Anyone have any updates or comments on this old thread....
Pure speculation, but the lower plate voltage class A of the C500 seems to be preferred by many over the higher plate voltage class AB of the latter version. The same reason why no one would even bother with the ultralinear version...And... Regarding past discussions here, I'm also not sure about the appeal of the 500 over the 500a. I would pick the later one for the choke input power supply. But, then again, I've only owned the later one.
less stress on the output tubes and less demand on the power supply...Pure speculation, but the lower plate voltage class A of the C500 seems to be preferred by many over the higher plate voltage class AB of the latter version. The same reason why no one would even bother with the ultralinear version...less stress on the output tubes and less demand on the power supply...
