Back in Sept '07, Paul C wrote:
I have an LPGear.com N97HE stylus plugged into this RXT6. It required trimming a little angled plastic section on top to fit, but that was quick and easy. That piece interfered with the plastic block glued on top of the cartridge body that sticks out, as can be seen in later photos. (Is there any reason that plastic piece on top can't be pried off and discarded? I'm tempted.)
As to your question at the end: In a word, no. I have three bodies here, all identical externally except for the ID--an RXT6, 800E, and RXP3. They all have that same 'cap', except the cap on the RXP3 was loose, and came off easily. Just a little epoxy under it.. With some gentle prying, I just popped the cap off the 800E. Any of the aforementioned styli should now fit with no trimming. Pop! there goes the one on the RXT6.
Many thanks to hakaplan, Paul C., et al. for the info. I might have tossed my RXT6 otherwise. When you have a dozen 'tables to feed, good sound on a budget is a must!
