allanmatters
Hello to all fellow audiokarma folks.
Yes it's another pop discussion. I know there's dozens of these issues here in this forum as well as others . Read through all still looking . System is a pioneer A-9
I decided to test the system . So for now its kept open for days . I sit with the system for at least 3-4 hours trying to find the issue . . I have wiggled twisted all PCB boards to get the source of the random pop sound .
Before that let me tell you that the system has been repaired in the year 2014 . The left side output transistors have been changed as well as many others on the equalizer board by a technician. It was was working fine until the end of 2017 . It started with random loud pop sound s which could occur at any time . And can definitely give you a fright. (It's really annoying) I even shared a link to a video I shot of it .
So the pops can come at any time . Sometimes when you ON the system after about 10 seconds . It's will pop a couple of time s and then maybe every 45mins or every 2 hours . Sometimes it never pops too . I checked the power amp board . Wiggled wires transistors resistors there. All solder joints are fine clean stiff. I still have to check the equalizer board (The board which has all audio inputs.) I even tested it with the speaker A and B buttons in the off position . Though no sound ,you can see the left VU meter jump. Which means it's still popping. So I guess the speaker relays are fine too
I have checked the bass control and treble control board . all fine . I still need to understand how to get access to the balance tone board .. I did keep the system exposed for about 3 and a half years . When I say exposed . I mean no cloth to cover it . No wooden cabinet etc. So eventually allot of dust has got into it . Since it was kept down stairs at the ground floor there's more chances of dust going into it .. I checked all switches and bass treble knobs power switch and balance knob as well . All those are fine (no pop sounds on adjusting them). It's seems purely random sometimes at any unexpected time . On big speakers the pop sound is so loud I feel like smacking it cause it's gives u a real fright .
Now its on test mode with small speakers connected so I don't get bugged with the loudness of the pop sound . Here are some photos
Do note that in the video it may look like adjusting the volume leads to the pop. But that is not the case .In fact I just switched on my system as i am writing this ,it popped after 1 min being in the on position. And it's popped on every 2 mins . And now it will probably pop later after 30 mins or any random time .
So this pop is clearly a random one . What should I look at next ?
