MadcapLaughs
Hello, I am hearing a rattling loose sound in the bass frequencies when I turn up my Scott LK 72 tube be amp up to moderately loud volumes, and it gets worse as you increase the volume from there. It is only happening in channel B. I have swapped the cables connecting to my speakers and the rattling swapped from the right speaker to left speaker. I also tried different pairs of speakers with the same results so I know it is the amp and that channel b in specific, my solid state sansui had no problem at all with my same speakers which are Altec boleros. Here are some additional troubleshooting done to no effect:
Swapped out all the 12ax7 tubes out with no change.
Reconnected all tubes to their sockets and tapped on all the tubes to see if there were loose filaments or anything rattling.
Tried a different electrical outlet and swapped the power strip that the amp was plugged into.
The amp has been thoroughly recapped and biased correctly very recently and had plenty of burn in time (if that's actually a thing) by the tech who worked on it.
Help me with some additional ideas as I am not sure how to isolate the issue. Everything else sounds great on this amp but the bass on the channel b sounds like a loose driver that is rattling in some shitty Honda with a subwoofer. Also this amp has this distortion in all preamp sections (phono, aux etc).
