This might be a strange question, but I'll ask anyways.
I have 2 stereo system setups: 1 in the den and 1 in my office. The den and the office share a wall and stereo system in the den is against that shared wall. In my office, the stereo system is on a different wall (not on the common wall). I'm mostly using digital music managed by both (separately) Plex and mpd. My computers and networking gear are in my office on the common wall with the den. I'd like to be able to run RCA cables through the common wall so that my stereo system in the den can play my music in either mpd or Plex. Would it be weird or inadvisable to set up an outlet box with female RCA jacks on both sides of the common wall and then cabling to connect all the way from my digital music library to my stereo system in the den? Would you do it this way? Any other setups that I should consider?
Thanks in advance!
Thanks in advance!
