markpilk
I’ve ended up with a case full of older rca component hd video cable from a friend. Most all look to be molded and I can’t see the gauge of wire. There’s 5 wires on each set and only two designated for audio. Are the 3 HD video rca cables the same as the audio?
Seems like I remember the older composite video cable were thinner gauge wire and I’ve never cut into the HD component video cables to see if they were the same. I’m thinking I can use them for audio if there all the same.
